Picture this...
joeyd999
Joined Jun 6, 2011
6,456
I helped my daughter develop the chassis for a balloon powered vehicle for her AP Physics class.
I knew those CD-R's, which I bought before she was born, would come in handy some day.20241006_150353.jpg
This thing glides like it's on ice.
joeyd999
Joined Jun 6, 2011
6,456
Nice! ... so you 3D printed the chassis, right? ... what did you use for bushings? I can't tell.
No bushings, just a simple journal bearing. The axle is highly polished 0.062" diameter piano wire, so the interface between the axle and the journal is nearly frictionless. The ratio of the wheel diameter to the axle additionally greatly reduces whatever friction is left.
There's a small polished washer on each hub that acts like a half-way thrust bearing, but there's no load on it so it's not really doing much but keeping the plastic parts from grinding against each other.
The hard and thin polycarbonate "wheels" eliminates any rolling friction, and the high moment of inertia keeps the linear velocity of the vehicle low for a given total kinetic energy thereby reducing drag.
The whole point of this vehicle: once in motion, stay in motion.
joeyd999
Joined Jun 6, 2011
6,456
If you put too much data on the CDs that would overload them and make them too heavy.
That would help!
Increasing the moment of inertia of the wheels increases the KE at lower velocities thereby reducing drag. I'm thinking of a revision where I can mount a large lead ring on each wheel to demonstrate this. Balance would be an issue, though.
35,130
That would help!
Ah! You are correct. I thought when you said balloon, that this thing was supposed to fly.
Then write the data on the outer tracks only. Make sure you write 64-bit data only.
