Gameboy dmg red Led no sound or picture
LeeUK
Joined Jul 1, 2024
14
Iv purchaced a gameboy that has power to the led but no picture or sound.
Iv tested the output from the battery and its outputting 6.4v.
Psu points are
Vcc 6.26v
Gnd 0
Minus -276mv
Plus -151mv
Now i no these outputs are wrong but im getting 6.24v on the board up by the switch when its turned on.
Strangly when i was checking the voltages i shorted the Vcc & ground together and the device started up, screen & volume was working and i was able to use the device, but when i turn it off it wont turn back on, would this suggest a short on the psu or on the board?
Theirs no noticble damage anywhere
Video to show what is happening
https://youtube.com/shorts/sdDZuYSCC0g?si=EUPsHENnATCAoXRk
Any advice appreciated
28,272
A trick that sometimes solves a problem is to disconnect and then reconnect each connector, one at a time so that nothing becomes confused. The reason that can work is because there could be a particle stuck in the connector, blocking the connection. So that would be one more trick to try.
LeeUK
Joined Jul 1, 2024
14
Ill try that once im home from work cheers :)
