PCB for dual gang pots
Justin20062003
Joined Jun 14, 2018
15
I need a pcb that I can solder dual gang potentiometers on that also has the 6 outputs to the sides or bottom. Anyone know where I can find these? Been googling for a couple hours with no luck. Or even anyone know where I can buy some presoldered 50k pots on the mentioned pcb in America? My usual supplier is way late on a shipment and I'm in a bind on getting some of these quickly
AlbertHall
Joined Jun 4, 2014
12,653
If I read it correctly, TS wants a board with the dual gand pot ready soldered to the board.
If you can solder wires to such a board, why not solder the wires to the pins of the pot?
Justin20062003
Joined Jun 14, 2018
15
I have 300 of them to solder so soldering to the board is just quicker. Soldering to the pins takes me more time. I will if I have to, just attempting to find some with boards
AlbertHall
Joined Jun 4, 2014
12,653
If you need 300 of them then it would be worth getting someone to make them specially. There are companies that will do this but I can offer no recommendations. Others here may be able to.
