Op Amp, trying to approach it again.
Xenon02
Joined Feb 24, 2021
504
Hello !
I know I've had this post about Op Amp, but I wanted to start this again with fresh mind (also there is a lot of pages and it's hard to find the answears :D sorry).
About Op Amp.
I guess there are only 2 questions? So comming with the first one : Op Amp with only negative feedback simple inverting OpAmp.
It is known that giving Vin negative input will result in reverting the input. So Vin = 1V will result in Vout = -1V.
Also V- is equal = 0V so that V- is equal V+. But according to this : Vout = Aol(V+ - V-), the output should result in something different ? Like Vout= 0V ? More logical would be if V- = 1V so Vout = Aol(0 - 1V). It is probably wrong but it is important for next question !
Second question is for both feedbacks :
I've had from the last post all calculations I will post them here
Here there are calculations for Vx (which is here V+) that it is equal to V-. But for the first one the Vx is positive and for the other one the Vx is negative while Vin is constant 1V positive.
I've heard that it depends on the which feedback is "stronger". I've seen those equations for stronger feedbacks, but I don't understand it when I look att this equation : Vout = Aol(V+ - V-). Let's take aside this "stronger" feedback equations. Why V- and V+ can't be negative while Vin is positive ? the results mentions that they can be equal so it should work.
Also the next answear was also because I have connected Vin which was positive to positive input, and ?I mean why connecting Vin to positive input must result in positive output when V- and V+ is not defined ? Unknown values. For the first question it is also a good question. Why Vin defines the Output ? when Vout = Aol(V+ - V-) and V- = 0V ?
If something is not clear I'll try to write it better.
35,207
For question #1 you are confusing Vin and V-.
They are not the same thing.
Let us assume for now that R1 = R2.
V- = V+ = 0V.
No current flows in the V- pin.
Calculate the current in R1.
Calculate the current in R2.
Xenon02
Joined Feb 24, 2021
504
V- = V+ = 0V.
Current in R1 is Vin/R1.
Current in R2 = Vout/R2.
I'm aware that V- isn't the same as Vin. I just mean that why Vin determines the Vout when in this equation Vout = Aol(V+ - V-) most likely V- determines. I just read that if I plug Vin to negative input then the output must be reversed for example 1V Vin results in Vout = -1V. Or somethine like that :D When I saw that equation I was like hmmm. Then why we say that Vin determines the Vout when V- determines it.
35,207
Because your equation is wrong.
Now, no current flows into V- pin.
What does this tell you about the currents in R1 and R2?
ericgibbs
Joined Jan 29, 2010
21,586
hi X02,
I would suggest that you first focus on the Inverting OPA circuit.
Gain for, -Vout = Vin( Rfb/Rin)
Do you follow that equation.?
E
Xenon02
Joined Feb 24, 2021
504
Exactly what do you mean by: I believe I do. Using the assumptions that V+ = V-.
Please explain.
E
Hi :)
I've calculated Vout using the assumption that V+is equal V-. So V- is = 0V it is grounded so current in R1 is equal the current in R2.
I am trying to grasp the idea how this : Vout = Aol(V+ - V-) works as well.
I just remembered that for positive feedback it was also possible to calculate V+ = V-. But it was incorrect because Vin if it was connected for example in positive input then the output shouldn't be reversed.
Wierd.
ericgibbs
Joined Jan 29, 2010
21,586
hi X,
You must define more clearly what you mean by V+ and V-.
Is your V+ the Vin Voltage on the Inverting Input and the V- the -Vin voltage on the Non Inverting Input of the OPA.?
E
Xenon02
Joined Feb 24, 2021
504
hi X,
E
I'm sorry :D
V+ and V- is the potential on the Op Amp inputs.
Vin is just the voltage that is connected to R1.
check the first image of this post :)
ericgibbs
Joined Jan 29, 2010
21,586
hi,
Ref your Vout = Aol(V+ - V-),
The equation is intended to be read this way.
Vout = Aol( Voltage on V+[Non Inverting] - Voltage on V- [Inverting])
So if Aol =10.
Voltage on V+[Non Inverting] = 0V
Voltage on V- {Inverting]) = -1
So Vout = 10( 0 -(-1) = +10
E
Xenon02
Joined Feb 24, 2021
504
hi,
So if Aol =10.
E
Okey :D
Sorry for asking, did you read my first post ?
Using this equation Vout = Aol(V+ - V-), and knowing that V- = 0V because V+ is grounded and V+ = V-. the Vout should be Vout = 0V.
More over, I read that where I plug Vin it decides what will be the Vout. For example 1V connected to positive input OP Amp, the Vout will be also 1V (or more the thing is that it is positive). If I connect Vin = 1V to negative input of OP Amp then the Vout is negative.
For both feedbacks it is not a typical sinlge feedback, so why connecting Vin to negative input of OP Amp then the Vout must be inversed ? V+ is now not grounded. The value of V+ and V- can be anything.
I've had the same issue with positive feedback, because there I also could calculate V+ and V- that they could be equall V+ = V-. But the problem was that because when I connected Vin = 1V to negative input of OP Amp then the output was also positive. And that was a problem and I don't know why. Even though the V- and V+ can have any value but must be equal, and Vout is decided by this equation Vout = Aol(V+ - V-). Not only by Vin connected to positive or negative input of Op Amp.
Jony130
Joined Feb 17, 2009
5,601
For a finite value of Aol, the (V+ - V-) will not be equal to 0V. Only for the case when Aol =∞. We will have V+ = V-
Xenon02
Joined Feb 24, 2021
504
Okey.
So how it works with both feedbacks (for now let's just ignore the fact of "stronger" feedbacks).
V+ = V- can be calculated for positive feedback and for negative feedback. For negative it works fine but for positive feedback it can be calculated but it is somehow wrong. Why ? If V+ and V- can determine the Vout, then why we say that Vin determines what is the Vout ?
For both feedbacks the value of V+ and V- can be anything, but for one example it will be okey but for the another it won't. Because Vin = 1V connected to positive input of Op Amp cannot give negative V+ and V-. Because Vout must be positive. I don't get this part. Why Vout must be positive ? V+ and V- can have any value and they determine the Vout.
35,207
Vout = Aol(V+ - V-)
“Same current flows in R1 and R2.”
So write this in the form of an equation.
Following up on what I posted,
V- = V+ = 0
Hence Vout = 0.
We know this is incorrect. Hence something is wrong.
As for the current equation, use Kirchhoff’s Current Law, the sum of currents in all branches equals zero. I am going to spell it out for you.
Vin/R1 + Vout/R2 + V-/R- = 0
35,207
Let us examine:
Vout = Aol(V+ - V-)
A large number multiplied by a large number gives a large result.
A small number multiplied by a small number gives a small result.
What do you get when you multiply a large number by a small number?
Xenon02
Joined Feb 24, 2021
504
V- = V+ = 0
Hence Vout = 0.
As for the current equation, use Kirchoff Current Law, the sum of currents in all branches equals zero. I am going to spell it out for you.
Okej.
V- = 0 so Vin/R1 = -Vout/R2.
So why doesn't it work for positive feedback, and why this : Vout = Aol(V+ - V-) is incorrect ?
Something in the middle ?
