One step closer to fusion...
cmartinez
Joined Jan 17, 2007
8,828
And there's the problem. I don't know about you guys, but when I was in college, the guys that flamed out of science or engineering went to the business or education schools. If they flamed out there, it was on to journalism. "Journalists" are the stupidest, laziest, most incompetent people I know. The general public holds them in low esteem for good reason.
Wayne, dude ... Clark Kent just called, he'd like to have a word with you ...
wayneh
Joined Sep 9, 2010
18,133
I have a few old things that don't like LED lights because of the RFI/EMI they generate. My classic GENIE screw drive door opener simply will not work (overloads the receiver) unless a incandescent bulb is in the socket. I bought a modern digital replacement years ago but the old guy keeps running.
My opener has a light socket that is oddly "deep", it requires a narrow neck on the bulb. Most CFL and LED bulbs simply can't be screwed in far enough to make contact. Old incandescents fit fine but tend to burn out quickly from the vibration. I've finally found an LED bulb that fits and I look forward to never touching it again. Maybe
They need money.
https://ignition-news.com/openstar-achieves-first-plasma/
What’s next? The plasma that the company achieved last month was a “minimum viable plasma,” Mataira said, but not the “full rated magnetic field of the magnet that we designed.” Next steps include kicking that magnet into higher gear to gather more data, as well as working out some of the other systems.
  • That includes the levitation piece, which the team is confident they’ll be testing in the first few months of 2025.
Next up, OpenStar will finalize the design for its next test machine and raise a round to make that happen. It’s also considering partnership opportunities and a base in the US for its next iteration.
https://www.scientificamerican.com/...n Systems (CFS),,news release issued by M.I.T.
Will the World's First Nuclear Fusion Power Plant Be Built in Virginia? Here's Why We're Skeptical
But let’s hold our nuclear horses for just a moment: there are several steps that must be completed before this fusion plant, named ARC (for “affordable, robust, compact”), could be plugged into Virginia’s power grid. For one, CFS has not finished its demonstration machine, SPARC (“smallest possible ARC”). The company says it expects the completed SPARC to show net energy production in 2027. That alone would be a feat.
The biggest fusion project on the planet, the International Thermonuclear Experimental Reactor (ITER) in France, is behind schedule and over budget, ballooning from an initial estimate of $6.3 billion in 2006 to $22 billion in 2023, as journalist Charles Seife reported in Scientific American last year. And ITER, whose fundamental goal is to prove that fusion energy is feasible, is not intended to power anything.
CFS, meanwhile, has secured about $2 billion in investments. If it succeeds, it will have done so where previous attempts by well-financed tech companies have failed. Lockheed Martin began working on a small fusion reactor in 2010. In 2014 it said it would develop a reactor compact enough to fit on a truck before 2019. But by 2021, Lockheed Martin had quietly shelved the project.
MrAl
Joined Jun 17, 2014
13,756
The science here is the Standard Model. A fusion reactor operates far below the energy regime where the Standard Model stops working so we know eventually the engineering needed will be done by someone.
I'm still betting on ITER being first.
wayneh
Joined Sep 9, 2010
18,133
Investment is one thing, but I smell a fraud here. NObody should believe they'll meet their alleged technical goals. I think their actual goals are all financial.
MrAl
Joined Jun 17, 2014
13,756
No. Those who can afford such investments usually can afford to lose on a few of them. And they win on lucrative others.
Perhaps you do not understand optimization. It's not always about getting to the bare minimum, it's about being able to improve things.
