One step closer to fusion...
SamR
Joined Mar 19, 2019
5,537
They had already spent a pile of money on it before they yanked the funding... Can't remember just exactly what the reason was. It was one of those massive engineering projects that I looked forward to seeing completed. Think it had more to do with Bush Politics than Engineering as the reason for canceling.
It was the ants that killed it.
https://www.nytimes.com/1988/12/15/us/fire-ants-to-make-building-of-atom-smasher-no-picnic.html
Residents of Ellis County, south of Dallas, where the super collider is to be built, say the ant not only inflicts painful bites but has also damaged home and farm equipment and caused power failures by chewing through underground cables, the department reports.
The atom smasher, to be built in a 53-mile tunnel under what is now farmland, would be used to accelerate subatomic particles to extremely high speeds and crash them into each other so scientists can learn more about the fundamental nature of matter and energy.
But s the Energy Department says the project will have to include special designs for wiring and other underground components, construction practices to protect workers from the ant's painful sting, and an environmentally sound pesticide policy.
"It'll get built. It'll get built sooner or later. It's the next logical step. It may not get to happen here." - Alfred D. McInturff
MrAl
Joined Jun 17, 2014
13,797
I can imagine that if it ever does become a real thing it will replace just about every energy source even oil. That's going to make some people with certain stock investments very sad and uncompliant.
MrAl
Joined Jun 17, 2014
13,797
You're right, the neutrons are a huge problem many teams seem to be ignoring, or hoping there will be a solution. LPP Fusion has chosen to solve the problem at the get go and is working on neutron-free fusion.
It's amazing how huge a technological problem this is and it's all based on: "If you make the temperature high enough they will fuse".
Reminds me of the old adage: "If you build it they will come".
Maybe the two are not that much different.
WBahn
Joined Mar 31, 2012
33,201
If what every becomes a real thing? The SSC? Sure, it would have opened up regions that we still can't explore, but I don't know how that would replace every energy source, even oil.
And even if fusion were to become a reality, you can't put a fusion reactor on everything and not everything can handle the weight of enough batteries to operate for the amount of time needed. Plus, despite the utopian dreamists, fusion energy is not free, in fact, it might well end up being quite a bit more expensive if the capital investments and much higher maintenance costs are considered -- and they HAVE to be considered. AFAIK, it's very much an open question whether a fusion plant could deliver energy to its customers less expensively the current fossil-based systems. We won't be able to answer that question until we actually know what kind of reactor and infrastructure is actually needed to make it work at all, much less be commercially viable.
Futurist
Joined Apr 8, 2025
950
The title alone strongly hints that if it isn't pure hype, it's probably presented in a very information-absent way.4 Could be wrong, but it just strike me as something that is aimed more at getting clicks than conveying something meaningful.
The subject is an operational business, with investment capital from a lot of companies including Google. All you had top do was visit the website of the company rather than denigrate the video.
The team are experts in the field, e.g.
Click here to learn more about stellarators.
Proxima Fusion
https://archive.ph/n68Xl
Helion quietly shifts goalpost on fusion energy
State of play: Helion this year removed a prediction from its website that Orion, the company's first commercial power plant, will begin producing electricity by 2028.
  • A Helion webpage for the Orion project now says the power plant will "begin initial operations in 2028." It does not define initial operations.
  • Full power won't come before 2029 or 2030, an executive acknowledged this summer.
  • "We will not, in no universe, have 50 megawatts hit full operation in 2028," Helion public affairs director Jackie Siebens said on-stage at the FusionX conference in Boston, per a transcript shared with Axios Pro.
  • The company declined to comment on this story.
cmartinez
Joined Jan 17, 2007
8,861
Update: fusion is now only three years away ...
wayneh
Joined Sep 9, 2010
18,168
That link seems to redirect elsewhere now and I can't find the original. Perhaps it was getting long in the tooth and was replaced.
But anyway, LPP and and other groups are looking hard at proton-boron fusion. It requires a much higher temperature to initiate but eliminates the neutron problem.
As for Helion, see the chart I posted in #232. They're stinking up the place.
