One step closer to fusion...
MrAl
Joined Jun 17, 2014
13,751
Well, it's just like everything else like die transistor size and 'savings' prices online, the numbers don't mean anything like they used to mean which used to be something concrete.
This is the also the case with 'Fusion' where they don't use the unit of the 'year' anymore, they use a stand-in for it that sounds like a date so people like the idea better.
So the year 2028 is really a sequence:
2028, 2038, 2048, 2058, etc., etc., etc,...
Who knows, maybe they meant to say "3028" :)
If Billy gets this up and running by the end of 2028 I'll make a donation.
joeyd999
Joined Jun 6, 2011
6,390
I think not.
TL;DR. But, I assume you are saying that 150°MC plasma is not a significant accomplishment (regardless of cost)?
Again, I don't know -- I don't follow this tech, generally. Mostly I think it's hogwash, mainly due to the pressures, densities, and temperatures that need to be sustained indefinitely to produce usable fusion.
MrAl
Joined Jun 17, 2014
13,751
The way I understand it so far is that the huge number of reactions are creating chaos inside a chamber and everything is just dying to get out of it :)
It's a huge challenge so it requires a lot of engineering.
It works in the Sun so we believe it can work in an artificial one :)
Two oscillators get close to each other, a certain force takes over, they join naturally like two magnets that get close. They combine in a nonlinear way and then require less energy to oscillate so the extra energy gets emitted as radiation.
MrAl
Joined Jun 17, 2014
13,751
A Tokamak is based on a completely different religion.
My original statements were:
I don't see how there can be any different 'religion' as they both need high temperatures and they both fuse particles.
The way they confine the stuff could be different, but then I never said anything about that, nor the duration of the high temperature.
So all I said was:
"Fusion requires high temperatures", and
"Particles fuse".
I'm not an expert in this field, so did I miss something?
wayneh
Joined Sep 9, 2010
18,133
The LPP team is working on hydrogen-boron fusion because, unlike deuterium-tritium, no neutrons are produced.
Excerpted from the link I gave above, referring to companies claiming they're beginning construction of fusion plants:
"In our view, none of these claims are at all credible. The problem is not the near-term goal of getting electricity by 2031. Lots of fusion companies, including ours, are aiming for similar goals. The problem is that none of these four companies have completed the scientific research needed to design a fusion generator. So, none of them can start construction of something they have not and can’t design right now.
How do we know they have not completed scientific research? The universally-acknowledged goal of the research phase of fusion energy is to achieve net energy in the laboratory—more energy out of a device than is put into it. That shows that electricity production is possible in a commercial generator designed on the basis of the net energy lab experiments. None of the four companies has reached net energy, none are close to reaching it and, in fact, none are anywhere near as close as LPPFusion is."
MrAl
Joined Jun 17, 2014
13,751
In both cases they produce energy by fusing two atoms with the generic name "hydrogen".
Beyond that, they are entirely different.
Oh so you are speaking more generally.
BTW, where was that thread that you said you realized something sort of profound about fields (i think it was fields).
I wanted to compare to something I was thinking about lately.
MrAl
Joined Jun 17, 2014
13,751
Was it related to this?
Well, that might be interesting too, but I am pretty sure you actual stated that you finally realized something about either fields or that everything could be fields or something like that. You also posted something about what I think was a start of a TOE if I remember right.
I wanted to re-read those.
joeyd999
Joined Jun 6, 2011
6,390
My theory is complete but not welcome here. PM me and I'll share, if you wish.
