MisterBill2
- Joined Jan 23, 2018
- 28,231
The clock will be a special case, with two counters, for minutes, zero to 59, for hours, 1 through 12, (or 24) One easy scheme will be two CD4017 devices in a counter ring, and then each output driving a single address to light the required segments. No software at all, not that much logic either.
The other scheme will be a binary counter presenting a hex output to an address in a prom, which delivers the segment selection for each number..
Setting will be a very simple process of adding a pulse string to the time base feeding the counter. one button to advance hours, another to advance minutes.
Counting the day's date, and the month will be more complex. Likewise showing AM and PM.
