Hey all,
I have a Tripp-Lite IS-500 isolation transformer I was going to use to float devices under test, when tracing with my Hantek DSO2D15 oscilloscope.
However, isn't there supposed to be isolation between the ground terminals of the input and output of the iso transformer? On my Tripp Lite IS-500 I am seeing continuity between the ground terminal of it's power chord and the ground terminals of it's output terminals.
This would essentially be just like plugging the device under test into a wall outlet as far as I can tell and not "Floating" it. Correct?
