Need help understanding this LDO topology
alfhg
Joined May 10, 2019
I'm trying to understand how a LDO topology works. It's in NXP IC's datasheet:
It has the control circuitry inside the IC with external transistor.
Parameters:
VDD output = 1.8V
Collector supply = 2.367V
NPN: Nexperia PBSS4620PA
L1: ferrite bead 26 Ohm @ 100MHz
C1 = 470nF
Rp = 1 Ohm
Rs = 0.15 Ohm
R1 = 49.9 Ohm
R2 = 18 Ohm
Voltage reference is supposedly a bandgap reference at 1.2V.
This topology isn't like the typical LDO, where the error amplifier feedback is taken from a voltage divider at Vout. In this circuit R1 and R2 don't have a ground path, but connect back to BJT base with AC coupling. How is this supposed to work?
I ran an LTSpice simulation to find the DC load curve. The result doesn't even make sense.
LTspice schematic:
(U1 is UniversalOpAmp generic model without input and output limits)
Vout vs RL waveform:
This doesn't make sense, because it's an LDO, Vout is expected to be always 1.8V with varying RL.
How should this work?
38,932
It makes sense.
In order for the voltage between the two op amp differential inputs be essentially 0V at balance with a 1.205V reference, the output will also be 1.205V due to the DC feedback loop through R2.
Makes no sense that you expect it to be 1.8V(?).
alfhg
Joined May 10, 2019
It makes sense.
Yes, I get the point, but according to NXP, it's using the same internal voltage reference (assumed 1.2V) to generate both 1.8V and 1.1V, with Vout determined by R1 and R2.
The suggested values for different Vout:
For Vout = 1.8V: R1 = 50, R2 = 18
For Vout = 1.1V: R1 = 110, R2 = 6.8
The datasheet is a new part provided under NDA, I'm not supposed to post it in public.
38,932
Obviously that won't work as shown since there is no DC path for R1.
Adding a resistor to ground from the left side of R2 would increase the output voltage, but I see no obvious way to get the output voltage below the reference voltage, unless an attenuator is added to the reference voltage.
