As I understand it:
T1 is the power supply to both circuits
T2 is the ground to both circuits
S1 is the trigger for L1 which then splits and goes to each headlamp assembly (can assign it low beam)
S2 is the trigger for L2 which then splits and goes to each assembly and powers the high beams
So my question is can both S1 and S2 circuits run simultaneously if I put say a relay or diode from the high beam wire to the low beam wire? Or will it ruin the relay? Is this dual coil? I couldn't find a lot of info on the inner workings of this online.
Also is this SPDT, DPDT, or any of those others... I couldn't figure it out
