I’ll be honest I am not.
But if I research it enough later tonight, I will be by tomorrow. I need to make sure I have the correct size solder tip. I did receive the flux today which helps with making sure the solder sits where it needs to be.
Is there a way I can check the CS5368 for proper functionality without removing it?
Is there a schematic you can send me for it?
Maybe, but it is not that simple.Is there a way I can check the CS5368 for proper functionality without removing it?
Pin-1 to Pin-4 (black probe on pin 1Remove the two 100Ω resistors (SMD code 1000).
This will isolate the 5532 opamp from the CS5368.
Repeat the resistance measurement from pin-1 to pin-4, and from pin-7 to pin-4 of the 5532 opamp.
where on the board shall I ground?RED lead at A, BLACK lead on GND
Ok. Use the mounting hole as your ground.All of them are close to zero
