Need help. 5V to 21V booster Circuit using MC34063
ronsimpson
Joined Oct 7, 2019
4,884
Looks good but; I can't see what you are doing the pin-5.
Are you trying to make 21V?
or are you trying to make 38mA?
---------------if you are regulating fro 21V------
I would connect BackLight- to GND. Make a voltage divider that that divides 21V down to 1.25V. In the example below R1, R2 divides 28V down to 1.25V.
-------Now that I look at it -----------------------------------------
Now that I look at your circuit it looks like you are regulating for 1.25V across R7. So, you are regulating current. That should work.
