Sorry, this is not the one. Even though its as long as a 14 pin DIP IC, it only has 8 pins. I will try to describe what I can measure at the pins, I will stick to naming the pins as it had 14: I can measure a dead short between pin 1 and 14; pin 2 and 13; pin 7 and 8. I can also measure a diode drop of 0,5 V with the diode tester of my multimeter between pin 2 and pin 6, no matter in which order I touch the probes to pins 2 and 6. However I can not measure a resistance that would indicate a coil in it. The relay looks like this:Hi, there.
Please verify.
