yeshi gill,
Is it connected as shown in post #7.?
Collector directly to 9v
E
hi,hi,
Bad idea, you may have damaged the transistors.
E
Hihi,
Rebuild with resistor between collector and 9v and retest, if it works they are OK,
E
hi gill,
Are you sure you have transistors connected correctly?
E
Now it works like an and gatehi,
You could put that Green LED in series with the collector resistor, say a 330R
E
Create circuit with NAND gates on Logisim | Homework Help | 3 | ||
NAND Gate circuit with HEF40107B dual 2-input IC | Digital Design | 22 | ||
Schmitt trigger based NAND gate | IC Design | 0 | ||
comparator circuit help | Homework Help | 12 | ||
I need help simplifying a circuit by removing redundant NAND gates | Homework Help | 5 |
