Nand circuit, placement of resistor.
gilleslag
Joined Dec 23, 2020
14
Hey everyone,
I'm new here and also a newbie who is teaching himself.
I have one question:
How come if i put resistor R1 before the output, the output is always 1? Even if A and B have an input signal.
gilleslag
Joined Dec 23, 2020
14
First I will say that i used different values for the components for my circuit.
these are my values:
power supply = 9V
R1= 330ohm
R2 and R3 = 3.3kohm
A and B are also connected to the power supply of 9V.
i hope this make sense :D
jpanhalt
Joined Jan 18, 2008
11,087
If you redraw the circuit with that resistor moved, you get:
Do you see why the output is always 6V, assuming negligible current? What if you eliminate that resistor (dashed line)?
Now if you short out the supply, i.e., both transistors are saturated on, then the voltage will drop depending on how much current the 6V supply can provide.
ericgibbs
Joined Jan 29, 2010
21,649
hi,
You could put that Green LED in series with the collector resistor, say a 330R
E
Update:
Added image.
