MaxHeadRoom
- Joined Jul 18, 2013
- 30,881
I wouldn't think the inertia was all that great to cause slow recovery, that motor should have very good response.
Max.
Max.
You want to find the maximum current that occurs during a normal functioning operation, you need to monitor a cycle where a stall does Not occur.will I need to measure the current draw when the wheels are spinning freely and also the current when a ball is fed between them?
| Thread starter | Similar threads | Forum | Replies | Date |
555-PWM Motor Control - MOSFET gets hot | Analog & Mixed-Signal Design | 30 | |
measuring 450nA | Test & Measurement | 8 | |
Measuring tiny currents | Test & Measurement | 27 | |
| Y | measuring time domain skew between two lines on a differential transmission | Test & Measurement | 1 | |
Measuring very low frequencys | Test & Measurement | 23 |
