No. You are probably looking at military spec'd connectors. Connectors of that type and size are not usually soldered on to the PCB. They are mounted on a solid metal panel.Are the pins in the image not soldered to the holes on the PCB side?
No pins on the drawing you posted.
| Thread starter | Similar threads | Forum | Replies | Date |
I'm trying to find 42-pin SDIP (1.78mm pitch and 15.24mm width) sockets | General Electronics Chat | 12 | |
Need feedback on ceramic substrate trace width calculator | Digital Design | 1 | |
| L | Maximum input voltage of op amp attenuator | Analog & Mixed-Signal Design | 5 |
