- Joined Jan 23, 2018
- 28,077
HDMI is the CHEAP JUNK implementation of DVI, which was a rather durable connector. At least some of the HDMI connectors used the poorer types of paper- phenolic PCB material and had a nasty tendency to break off way to easily. I would really like there to be some rules as to what quality level of materials can be imported, so that the real junk can go straight to the recycle centers without ever being sold. AND, for that matter, forbid the sale of any coaxial power connection with the center negative. ( That is a peronal prejudice of mine, though).By "bloat" I was referring to the hardware bloat from four to 24 pins - the number of pins for a serial device when from 25 to 9 to 4 to 24. (DB9 was not the ultimate in connection reduction) Or does USB-C have aspirations in becoming HDMI?
Every device that needs charging has some type of buck or boost regulator in it. So why not fix on ONE charging voltage. 12V should do nicely. I can imagine that any device runs (or can run reliably) on the raw USB power input - they will all be regulated in one way or another. It will be a long time before I believe that a connector that small will deliver 240W reliably and safely. Two pins in parallel to carry 5A and a contact resistance of 50mΩ give over a Watt of power dissipation, which seems a lot for a connector of that size (I'm comparing it to a TO220 case power transistor).
I've only ever bought one USB-C lead, for an iPad Pro. There were a lot to choose from, and I just bought the first one I found of the right length - they are universal, aren't they? So any would work. And it didn't.
It will only be a matter of time before the de-factor USB-C connector is a 24-position connector with 4 contacts fitted, and the number of wires in a de-facto standard lead has also been reduced to four.
