Put "Ground" to circuit.Hello ! I am trying to simulate a simple schematic but it takes too much time for the software to simulate it.
This is what I found on the output of the PSU (the green trace):
It will blow up at 40V in either circuit.The reason for using that circuit is the possibility to use a higher voltage transformer for example a 33Vac transformer, which is over 40Vdc after rectifying and filtering.
by Robert Keim
