LTSpice simulation of circuit
Ian0
Joined Aug 7, 2020
13,227
I need maximum 25V at output. I tried some time ago with a 24Vac transformer but when I set the output voltage at 25V and I connected a constant 3A load (like a resistor), then on the scope the output of the power supply was not a perfect horizontal line, it looked somehow strange (I deleted the screenshot with the scope screen from my pc)... the output which should be a horizontal line was a horizontal line in combination with the ripple on the filter capacitor.
Did you have enough smoothing capacitance?
Ripple ≈ It/C
Ian0
Joined Aug 7, 2020
13,227
If you are running out of headroom then a Sziklai pair would get you a Volt closer to the power supply.
ericgibbs
Joined Jan 29, 2010
21,531
hi mike,
Ref the 2N3055, see image. Worst case hFE is 20 at Ic of 4Amp.
Also, the LM723 max output base drive current is 150mA
So I would expect 20 * 0.15A = 3Amp as the minimum possible C?E current.
Give it a try.
E
mike_the_begginer
Joined Dec 7, 2019
137
I can see that the current through the load (R12) is very high but through the R21 (0.15R) it is about 36A, which means it is 12A through each power transistor.
ericgibbs
Joined Jan 29, 2010
21,531
hi,
I was under the impression that you are designing a 28Vdc @3Amps power supply.
The high load current spike is due to dumping the 28V charge on the C2 1000uF, when switching load On
The 0.15R emitter resistor should limit the Iout to 4A max, after the spike.
Have you revised the specification.?
E
mike_the_begginer
Joined Dec 7, 2019
137
Hello @ericgibbs , I found a schematic which is tested and it is functional. I tried to do a test with the oscilloscope, it does not oscillate at this moment but the output voltage is going down with about 200mV when connecting a load, even if the current limit is set at about 4A and I connect a 3A load. The output voltage was set at 29Vdc.
I tested using different potentiometers, different LM723, different driver transistor and it looks like the problem persist even if I replaced the mentioned components with new ones.
ericgibbs
Joined Jan 29, 2010
21,531
hi mike.
I have drawn out the circuit.
E
Note your pin723 pinout locations are slightly different from mine, move to suit.
E
[/ATTACH]EG57_ 547.pngEG57_ 549.png
mike_the_begginer
Joined Dec 7, 2019
137
Please find attached my simulation.
I have seen on the scope that the output voltage does not return to the set value. While the load is ON, the voltage is about 200mV under the set value.
