LTC6991 oscillator not oscillating
Papabravo
Joined Feb 24, 2006
22,082
Did you connect the SET to GROUND through a High Value resistor, or did you imagine that it was the same as connecting directly to GROUND? It sounds like you have no idea how to interpret the block diagram on page 8 to realize the importance of that resistor and what purpose it serves. Connecting SET to V+ has absolutely got to the most wrong thing you can do.
captoro
Joined Jun 21, 2009
207
Of course. I have 400k ohm resistor connected from Set to ground.
Papabravo
Joined Feb 24, 2006
22,082
That was certainly not clear from your original post. I'm going to say this just once. We need a schematic diagram of what you have built, complete with reference designators, part numbers and values. Do not under any circumstances point us to a picture from a datasheet or another website. Those pictures and your verbal descriptions do not contain the information necessary to help you. Comply and help may be forthcoming. Ignore this request and you are on your own.
captoro
Joined Jun 21, 2009
207
captoro
Joined Jun 21, 2009
207
Hi, I tried it, I shorten the wire, I even added 3 wire total from SEt to ground. Still no output. I also used another LTC6991, same output.
ronsimpson
Joined Oct 7, 2019
4,695
SET through resistor to VCC works and I think it should not work.
SET through resistor to GND and it does not work but should.
How strange.
You must have got you bread board from the same place I got mine. Looks the same. lol
captoro
Joined Jun 21, 2009
207
On your breadboard, I see no connection between the - rail at the bottom and the - rail at the top.
Bob
Hello Bob,
The connections are on the extreme right. OUt of range of the picture.
I tested the voltage with a voltmeter and its 5V.
captoro
Joined Jun 21, 2009
207
Still no output if its (RST) floating. I touched it with my fingers and got it to oscillate randomly.
du00000001
Joined Nov 10, 2020
189
Had a look into the DS: capacitance parallel to the SET resistor has to be kept below 100 pF (the lower, the better - see P.7) to provide stable oscillations.
And these fancy breadboards are notorious for their parasitic capacitances. Sometimes it's better not to use a breadboard but wire a circuit "free".
RPLaJeunesse
Joined Jul 29, 2018
262
Here is the schematic
FWIW your schematic doesn't show pin numbers. Did you just assume the pins were depicted in the correct numeric order? That's a BAD assumption. Did you look at the data sheet to get the proper pin numbers? Not apparent. How do you know you have the pins used in the way the schematic indicates? Also, the 0.1uF bypass cap should be across the device power pins, right at the device, with short leads. I didn't even see it in your picture. Could explain your problems.
