Hornett
Joined May 15, 2026
27
Hello, I am a bit hesistant to ask for help and im sorry, but I have a final project due soon and i have to build an attendance system but I'm struggling a bit and I'm cramped on time due to previous exams and projects,
In it I can only use IC Chips and no microcontrollers
It has 4 switches (Student Enters, Student Exits, Lock Door, Reset Session):
- Everytime a student enters or leaves, I should have a 7-Segment Display that displays the count of the students in the class (0-30) Max Capacity is 30 [I should have bits covering 30 states)
- When the door is locked, the student count can't change, if it is unlocked, the timer resets and student count doesn't change
- When the reset switch is set, both capacity and counter timer will reset
It should also have a 10 second countdown, so two 7-Segment Displays (10-0)
Additionally I have to Design my own clock using a 555 Timer which I found this for
Initially: 0 Students, 10 Timer starts counting down
LED Outputs:
- Green LED light indicating if the entrance is allowed (Under 15 Students, Above 5 seconds left)
- Red LED light indicating if the entrance is restricted (Locked Door, 30 Maximum Capacity or Countdown hit 0 seconds)
- Orange LED indicating if half time passed or half capacity achieved (Above 15 Students in, 5 and under seconds left)
Display Outputs:
- A seven-segment that displays the Time remaining for entering (Count Down from 10-0) (10 seconds) [If this gets complicated I was thinking to make it 9-0]
- A seven-segment that displays the number of students remaining (0-30) [Two 7 Segment displays)
- A seven-segment that shows O if the access is allowed and L if the door is locked
Its also required of me to design a Finite State Machine and a state table, in it, a RESET state is required and for the state table should be built up using current states bits, inputs, outputs, and next state bits
then ill use the state table to get the functions of the output
At the end i build it everything on Quartus then build the hardware and then do breadboard soldering and pack the design
Can i please get any advice or help?
atferrari
Joined Jan 6, 2004
5,032
LED Outputs:
Display Outputs:
Solve the most difficult part first
The clock, if you have minimal idea of what it is, should be, dare to say, trivial for you.
Buena suerte.
dl324
Joined Mar 30, 2015
18,522
When is the assignment due?
What logic family are you going to use? The 555 timer is available in bipolar and CMOS, but the bipolar timer typically interfaces with CMOS without needing a pullup resistor on the output.
This will probably take the most time, so plan accordingly.
Hornett
Joined May 15, 2026
27
Its due in 20 hours but i have a team of 2 other people with me, on the bright side all the other teams are in the same siituation as us
I'm gonna use TTL ic chips (like 74LSXXX)
Yeah its a bit hard, im probably not gonna finish it in time
Hornett
Joined May 15, 2026
27
How much time were you given?
Honestly the last couple weeks of the semester but we had other projects and exams (including a heartbeat sensor and application designing and other hard exams so only now were we able to find time
Have you done this part?
Yes I just did the FSM
S0 is RESET state (initial state and is required), S1 is OPEN with outputs Green LED and display O (Open), S2 is Half state where output is Orange and display O, S3 is CLOSED state with red LED and display L, and LOCKED state which is the manual lock
dl324
Joined Mar 30, 2015
18,522
I haven't yet as I'm helping divide the tasks and we just finished the counter (not countdown)
But formal design is state machine, state table, then implementation. So you've skipped a step.
Also:
Students in the class and students remaining sound like different counters to me.
Hornett
Joined May 15, 2026
27
Oh, yeah sorry I had an error, its number of students remaining
Yes but we didn't have much time so they decided to hurry with a counter at first, and in regards to the state table.. well im struggling a bit right now and I don't even know If i'm doing it correctly
dl324
Joined Mar 30, 2015
18,522
It's definitely not complete.
You should have all combinations of the inputs combined with the current state of the counters.
Also, the "Registers" box mentions flip flops. Are you allowed to use up/down counter ICs? Or do you need to design the counters using flip flops?
If you've paraphrased the problem description, the actual problem description would be helpful.
Hornett
Joined May 15, 2026
27
Yes I'm still working on it, my main issue is that do I need to put the next state for all 5 bits that cover all 30 states? Or can I remove it representing for example when there's 2 to 12 students I can remove it from the state table and only put the states where there's change
The system will use FSM to check if the student has completed a valid entry or exit sequence, and will use a 5-bit synchronous up/down counter to maintain the number of students currently in the classroom so yes i can use an up/down counter
and there's also:
- The system will use feedback from the counter (ZERO and MAX) to impose conditions that will prevent the counter from underflowing (going below zero) and will limit maximum occupancy of the classroom to 30 students.
- The system will be locked if the maximum number reached, after 10 minutes from the start (consider 1min equivalent to 1 sec in your design) or if the instructor decided to lock the door."
dl324
Joined Mar 30, 2015
18,522
So the students counter starts at 0 and counts up to 30. That makes a difference on the count that's decoded to lock the door. At any rate, it's an up/down counter.
It would be a good idea for you to post the complete text of the problem to avoid confusion.
Hornett
Joined May 15, 2026
27
Yes ive pretty much sent everything though.. I still don't know how to work an up/down counter frankly though, half of my semester was butchered due to the war in my country and everything was pushed into cramped dates
Hornett
Joined May 15, 2026
27
Since you want to use 74LS, you have two options. I'd choose 74LS192 to have a clear option.
Okay thank you for the recommendation
Do you mind me asking what country you're in?
Lebanon, my uni is in the capital which was being bombed so we couldn't go to our laboratory sessions and other sessions so everything was pushed into a tight schedule thus.. today
dl324
Joined Mar 30, 2015
18,522
You have my condolences. The World is a crazy place these days.
If you post anything from Quartus, turn off the grid and print to black-and-white PDF.
Are you going to actually use 74LS chips or are you going to program that Altera FPGA board that (I think) connects to Quartus.
