schmitt trigger
- Joined Jul 12, 2010
- 2,224
Don't see a reason for a particular preference.5...Last one, Am I correct in saying, there are two ouput conditions for a LM723, a high and a low, 1.5v to 7v and 7v to 30v.
For the lower v. range adjusting the Vref to ground is preferred, and the higher v range, adjusting inverting pin 4 to ground.
Thanks for the tip, just looking at it now, there is a lot in there very detailed.To your question #1: level shifting.
To answer all of your questions in exquisite detail, and show dozens of 723 circuit configurations optimizing different parameters, please look for the book shown below. Chapter 3 discusses the 723 in detail.
Ok Gentlemen, re-group,...... I did'nt expect such a downpour of help and pdf's , I'm viewing this on a Desktop, I find lying horizontal and looking at such material on a tablet less pressure on my small brain.Thanks for the tip, just looking at it now, there is a lot in there very detailed.
1. Zener diode shifts out voltage of LM723 in the middle of its dynamic range.1...The 5.1v zener diode at pin 10, what is it's function? (previous opamp power supplies I've made require a resistor here to keep the current output of opamp within tolerance)
2...Resistor 306 1k, I see this a lot in Darlington pairs, is it not just increasing LM723 output load.
Thank you Danko, didn't know this, this whole conversation has been very informative1. Zener diode shifts out voltage of LM723 in the middle of its dynamic range.
2. Resistor in Darlington pair shunts current leakage of first transistor and, also, increases its β.
| M | LM723 + Power MOSFET doing linear regulation ..#2 | Power Electronics | 9 | |
Help needed with Floating Positive Regulator LM723 | PCB Layout , EDA & Simulations | 29 | |
| Y | Using TIP2955 with LM723 | Power Electronics | 12 | |
| X | LM723 + Power MOSFET doing linear regulation | Power Electronics | 14 | |
LM723 power supply | Power Electronics | 2 |
