Yea I've probably fried about 7 so far - I bought a ton for cheap anticipating a painful learning process.If it is wired correctly, frying usually is caused by oscillation. That's the only time I've seen one die. I killed a TDA2003 the same way, then learned.
Here's my other circuit that WORKS.
From what I can tell, it is wired up basically the same, but I use different values, and I had added the VCC bypass cap without really knowing what I was doing. It's really surprising to me that this one works so differently from the first one - the values don't seem too different.
I'd appreciate any feedback on what I'm doing good / bad here - I based it off the one from Mims's book, and it seems to work ok.
