Linear rectifier circuit
Pyrex
Joined Feb 16, 2022
556
Hi, colleagues
I want to built an ESR tester, powered from a 2.4V Ni-Mh battery ( 2xAAA). The moving coil meter, 200uA 500 Ohm to read the value will be used.
Stucked with the rectifier stage. I'd like to avoid using of a special Opamps or special ICs. Can anyone point me to a circuit diagram ? Accuracy of 5% is acceptable. The previous cascade impedance is 10 kOhm, maximum output is 100mV, frequency is 100 kHz.
Circuits from a college books is out of interest, I need a real circuit diagram...
Thank you in advance
sghioto
Joined Dec 31, 2017
8,756
Does it have to be 2.4 volts? A lot of the circuits I have seen draw very little current and a 9 volt battery would suffice without taking up any additional space.
Alec_t
Joined Sep 17, 2013
15,157
If you've only got a 2.4V supply I'd be interested to see if anyone could could come up with a precision rectifier with 5% (or even 10%) accuracy. Even Schottky diodes would eat into that voltage allowance.
Pyrex
Joined Feb 16, 2022
556
No problem . I have some HF germanium transistors and small signal germanium diodes.
Some time ago I saw an ESR meter powered from a 1,5V battery on a forum. It was crystalradio.cn link , I guess. Sorry, can't find the circuit diagram at the moment
Hymie
Joined Mar 30, 2018
1,347
If the op-amp is notionally operating at unity gain (with the feedback), and you want a voltage output swing of less than +1V then an op-amp with a 1MHz bandwidth should easily do the job. There are a number of fairly inexpensive op-amps with a 1MHz bandwidth – but I’d recommend you test the circuit design using LTspice.
Pyrex
Joined Feb 16, 2022
556
Really ? A quite fast opamp OPA2211 ( slew ratio is 27 V/us , unity gain BW is 45 MHz), shows a clearly visible distortions at 100kHz :
Precision Full-Wave Rectifier, Dual-Supply
AnalogKid
Joined Aug 1, 2013
12,281
Please indicate the figure or paragraph you are referencing.
If the author had run multiple generations of opamps through the same circuit, you might find that the distortions have more to do with the device's internal topology than simply its bandwidth. IOW, I wonder how an LM318 from the 1970's would perform at 50 kHz. Same for a current-feedback opamp from the 1990's.
Also, don't confuse simulation results with the real world. TI knows a lot about modelling, but I wouldn't trust anyone's models when chasing this kind of subtlety.
BTW, nice find on the article.
ak
Hymie
Joined Mar 30, 2018
1,347
A little while back I was experimenting with an LT1361 dual op-amp with a 50MHz bandwidth. Although having a maximum 36V rail, there is no way that the device can output a sine wave with peak to peak (0-36V) even at 10MHz unity gain.
The datasheet shows the undistorted output voltage swing limited to 10V (p-p) at around 5MHz. But I would be very surprised if the LT1361 would not be suitable in your application. I think I purchased 5 for around $15 including p&p from an ebay seller.
