Lead-acid battery charging circuit
alireza770717
Joined May 14, 2024
20
"This schematic is for a lead-acid battery charger circuit. I've set up this circuit, but it's only charging at about 15 milliamps. Can anyone help me troubleshoot this problem? By the way, all component values are according to the schematic, except I used a 13-volt transformer instead of a 15-volt one." ش.jpg
ericgibbs
Joined Jan 29, 2010
21,629
hi alir,
The 13V transformer is the problem, a LM317 requires approx 3V across it in order work correctly.
Also a 0.7V drop across D3 is a problem.
E
ericgibbs
Joined Jan 29, 2010
21,629
hi alir,
No, I am saying it is adding to the problem of low voltage at the battery, when using a 13V transformer, when trying to draw a high battery charge current.
What are the details of the transformer VA rating and the battery type and AHr rating?
E
alireza770717
Joined May 14, 2024
20
hi alir,
E
I'm using a 12-volt, 5-amp-hour battery and a 13-volt, 3-amp transformer. Would you be able to provide a circuit diagram that could replace this setup?
38,926
My sim shows you should be getting normal charging current even with a 13V transformer.
What are the voltages at LM317 pin3 and pin 2?
schmitt trigger
Joined Jul 12, 2010
2,276
Per Cruts’ request, please also include the voltage in pin 1 of the LM317.
The reason is that the voltage difference between 2 and 1 should be 1.25 volts. If it isn’t, then the LM317 isn’t working.
alireza770717
Joined May 14, 2024
20
The voltage at pin 1 is 10.10 volts, and the voltage at pin 2 is 10.49 volts.
Adjusting the potentiometer does not change the voltage at the pins.
