That transistor has a maximum collector current of 100mA, so you can only drive 5 LEDs (with no safety margin). If you use it as a switch, power dissipation shouldn't be an issue.im using BC547 transistor
Hmm. Arent those resistors in series and in series current is the same? so they should both have 3A?You use the current divider equation for parallel resistors. If you have 3A flowing through 0.5Ω||1Ω, 1/3 of the current will flow through the 1Ω and 2/3 will flow through the 0.5Ω.
That's what I recalled, now I need to look it up...dl324 25 ohms / Ie - how can ohms divided by ampere can give as resistance ?? Also why you mixing a small-signal parameters with DC?
And re is not a resistance seen when we looking into the base terminal.
No, they're in parallel (that's what || means).Hmm. Arent those resistors in series and in series current is the same? so they should both have 3A?
Oh yes, i misunderstood.. I thought u were talking about the R1 and Rldr.No, they're in parallel (that's what || means).
I reduced the divider resistors to 1 and 0.5Ω and left the BE resistance as 1Ω. The ratioed LDR resistance is in parallel with the BE resistance. That's the current divider I was referring to.
Essentially. We usually think of current going through resistors and voltage being across them.Vout or as u typed VLDR is the voltage that will go through those resistors and will go to B-E junction?
As Jony130 pointed, I have a problem with units and using AC parameters for DC. I still think the approximation is close and good enough. You're looking at the resistance of a PN junction who's IV curve looks like similar to the LED curve I posted earlier. Resistance is the slope of the curve, so higher resistance at low currents and lower resistance at higher currents.Yeah okay. Hm and why did u say the b-e junction resistance is 1 Ohm? How did u calculate it? or u just gave and example with random number
If I understand you correctly, that's not correct.For example if the R ldr when the room is light will be lets say 100k and the R1 is 50K ohm, so the current would be I=4.5/150K=0,03mA , so lets assume thats not enough to light LED?
Waaaitt.? I thought for our circuit to operate we need the transistor to turn on , not to prevent it from turning onFor your circuit to work, the "light" resistance needs to be low enough to prevent the transistor from starting to turn on
Since you're using an LDR, I assumed you want the LEDs on when it's dark and off when it isn't; so you have to prevent it from turning on when it's "light".Waaaitt.? I thought for our circuit to operate we need the transistor to turn on , not to prevent it from turning on
It's allowable if it's your thread...By the way, little off topic
LED forward voltage is for a specific current. If it isn't mentioned, you assume the current used in the datasheet; which is typically 20mA (or 10mA for LEDs from a couple decades ago). I would assume 20mA.i came up with the problem finding out the actual voltage drop across the leds. I connected different coulours LEDs to the 4,2V battery and measure the voltage across the LED , and the measurements differ from what is written on the LEDs package they gave me when i bought those..Any ideas?
by Robert Keim
by Jake Hertz
by Aaron Carman
by Jake Hertz
