Boost Convertor not Working as Expected
vandveuser16776
Joined Feb 21, 2026
230
Hi guys.
I have spent hours but I cannot figure out what is wrong with the design. The output does not yield anything unless I increase the Boot cap to ridiculous 50uF. The 1:6 ratio still does not give anything remotely close to x6.
Here is the schematic. The duty cycle is near 50%.
schmitt trigger
Joined Jul 12, 2010
2,229
Divide and conquer.
As a very first step, replace the 1N4148 with a proper fast recovery diode like the UF4007.
Then we’ll start figuring it from there.
Also show the waveforms for Bin and Tin.
38,805
That's because you do not have a 1:6 turns ratio.
The reflected inductance is proportional to the square of a transformer's turns-ratio, so you need 36mH on the secondary for a 1:6 turns-ratio.
You need to brush-up on your transformer theory.
And a ST noted, the 1n4148 is not appropriate for this application, as it is a small signal diode, not a power rectifier.
Best to use a Schottky rectifier for good efficiency.
vandveuser16776
Joined Feb 21, 2026
230
Thanks! So it is not the same as ferrite cores? I learned something new!! :)
