Boost convertor
gokulpradeep010
Joined Jun 2, 2021
42
Hi all,
I am trying to build a boost convertor ckt using LT3757A for 24V to (180V,0.1A). I am getting the required voltage, but my voltage drops to 65V when a load is connected.
inductor- API Delven 220uH,
Mosfet - IRLI640GPBF,(200V)
Output capacitor( 4.7uF, 250V ESR 490m), KEMET
BobaMosfet
Joined Jul 1, 2009
2,211
Hi all,
I am trying to build a boost convertor ckt using LT3757A for 24V to (180V,.1mA). I am getting the required voltage, but my voltage drops to 65V when a load is connected.
That most likely would mean the load is taking more current than your Boost Converter is providing- Make sure you understand how much current the load demands.
Papabravo
Joined Feb 24, 2006
22,116
Building a boost converter with a ratio of 7.5 to 1 is going to be a challenge regardless of anything else you do. I'm uncertain if this enterprise has any chance of success. Do you have some reason to be hopeful? Certainly a ratio in the neighborhood of 3-4 is reasonable.
ronsimpson
Joined Oct 7, 2019
4,888
Part number. Will it work at 1 to 2 amps? Is it saturating? Send picture.
The LT3757 current limits when pin 5 gets to 0.108 volts. There is a 0.09 ohm resistor on pin 5. 0.1 ohm is easy math. There will be 1A average through the transistor so the peak is above the 1A limit.
I know you are current limiting. Try 1/2 the load and see if it regulates.
Many people do not check for saturation on inductors.
gokulpradeep010
Joined Jun 2, 2021
42
The part number is:
4590R-224K
ronsimpson
Joined Oct 7, 2019
4,888
I think you are trying to pull 2X too much current.
The IC is current limiting and the inductor is right at saturation. 1.2A
-----edited-----
The fact your voltage drops to 65V from 180 suggests you are 2.5X maybe 3X too much current.
