I don't know about that AG. I'm one of those one in a million that it affected differently.AG said:If everybody gets a flu shot early then nobody will get the flu. The flu shots prevent spreading the flu around.
I STILL like Led Zepplin and also Jefferson Airplane and even Iron Butterfly. Rock and Roll Forever.I like some Pop too. I like a little of all music, I even like some country "songs".
AG.....? at your age?
I also missed the pile of stuff, but I routinely do not get alerts for threads I'm watching. I've pointed it out to the mods a few times, but they have not found anything broken.One thing is really puzzling me is why I missed a few hundred postings on this thread.
Mounting holes do not need plating hardly ever, so don't waste your money on that. But having solder on the lead all the way through makes an assembly much more durable against vibration. Much harder to unsolder but that is a tradeoff.Not sure if I need plated holes or not. Probably might help for the mounting holes but the heat sink holes I'm at a cross road. If I place a plated hole around it, it would only give another plated surface to get hot. And I remember everybody telling me to give everything as much room between components and route lines as I could. BUT! there is only so much room you have between the pins on the IC anyways.
Yes MisterBill I know I need the drill files. It was a stupid mistake on my part.
But it also makes soldering easier in some cases. If components are tightly packed, you have the option of soldering on either side of the PCB. In fact, most of my PCBs have all components on one side, but I solder them on the other. My iron isn’t encumbered by other components.Mounting holes do not need plating hardly ever, so don't waste your money on that. But having solder on the lead all the way through makes an assembly much more durable against vibration. Much harder to unsolder but that is a tradeoff.
I misunderstood your post. I thought you weren’t plating the component holes.The way I designed it you can solder on either side but that's because of the route lines being on both sides to keep them from crossing. It's a simple 2 layer board. I'm mounting the IC and heat sink on one side and all the other components on the other.
And thanks for posting djsfantasi
I’ve read the whole thread.I'm still trying to learn djsfantasi. It's my first electronic project. Just to catch you up I'm 58 and before coming to the site I knew nothing about electronics. Well I knew about components but how they worked with each other that was another matter. The guys here are the greatest!!!!
Helped where I needed it and didn't ask for a dime. You can't find that anymore.
| Y | VNA calibration linked causality questions | Wireless & RF Design | 1 | |
| H | Questions on RFIC and Electromagnetic design | Homework Help | 1 | |
Current draw questions | General Electronics Chat | 37 | |
| T | Solder composition questions | General Electronics Chat | 9 | |
| C | basic questions about soldering. Beginner | Technical Repair | 47 |
