- Joined Jul 18, 2013
- 30,813
Reminds me of the question often posed to Electrical apprentices quoting the old regulation for Kitchen outlets and still valid in some jurisdictions.Current wise there will be 23ish amps at 120v available, minus losses . It just needs to be 2 phases because houses here are wired with multi wire branches and it's possible to overload the shared neutral if it's all on the same phase.
Where outlets are wired with 3 wire and gnd and a top outlet is wired for one 120v L1 and the bottom one L2 with a shared neutral, if an identical 10amp load is plugged into each outlet, what is the current in the neutral?
