I want to controll electronics made for AC with DC. In the specs it says 60 volt AC and 5W. Is it possible to use an inverter and translating 60 vdc to 60 vac? Or how can I calculate this? My idea is to simply put an inverter between but since I am pretty new to AC I am not sure if it would be that simple. So for example if I lower the vdc will that also lower the ac in a linear way?
