Handuro inverter board repair help"
panic mode
Joined Oct 10, 2011
5,469
terminal block is defective. it is melted. typical but not the only cause is loose connection, causing it to heat up over time. instant overcurrent can blow things up but normally does not have time to melt things. you can start by disconnecting wires and checking continuity across IGBTs to see if they are shorted, check bottom side of PCB for blown tracks....
