Sequencing of Hex Inverter Input
SamR
Joined Mar 19, 2019
5,542
I do not understand the sequencing of the second Hex Inverter inputs circled on this schematic. Aren't the inputs of a 7404 individual independent inputs? I initially wired them the second inverter 1,3,5,9,11 and it doesn't work! When wired as shown on the schematic it does work? What difference does it make what order the independent inputs are used??? Yes, I did use the correct output from the input for LED.
Futurist
Joined Apr 8, 2025
952
When you initially wired that second inverter chip 1,3,5,9,11 did you also wire the outputs 2,4,6,8,10 ? (listing pins "downwards" on the diagram).
So long as pin 6 from the 7442 gets routed to LED 5 (and so on) it will work.
SamR
Joined Mar 19, 2019
5,542
Doesn't work means the LEDS after the 5 from the 1st inverter did not light up in sequence correctly on my first try wired 1,3,5,9,11 on the 2nd inverter. It does light up in sequence correctly after I reverse ordered the second inverter as shown in the schematic? So, I am baffled what would cause that? I didn't think it would matter either, so I initially wired them 1,3,5,9,11 with no joy. Maybe I did wire the outputs as shown on the schematics the first time but indexed the inputs 1,3,5,9,11? That is the only answer I can come up with?
SamR
Joined Mar 19, 2019
5,542
OK, I must have! Went and tried again with 2nd Inverter 1,3,5,9,11 and correctly wired the outputs and it works! Thanks guys!
dl324
Joined Mar 30, 2015
18,523
The inverters are independent of each other, but I once had a quad DFF on a ROM board in an HP 3000 Series III that only failed with certain input combinations.
Rewire as you did originally and swap the two 7404 to see if the problem goes away.
SamR
Joined Mar 19, 2019
5,542
I was puzzled when I first read the schematic as to why the 2nd inverter was wired in "reverse sequence". I guess it was to show that the sequence was nonessential as they are indeed independent!
panic mode
Joined Oct 10, 2011
5,469
or whoever made it was trying to optimize it for his board design. i always start with neat and uniform order but to make PCB simpler, often change it, specially for connectors and terminal blocks.
at any rate different order of inverters as drawn is not the reason for circuit to not work.
28,597
Now, a month later,I can add that while all those gates are quite similar, that actually depends on how close you look. In addition, all of the interconnection wires can certainly have an influence, as I have learned over the years.
Like has been stated elsewhere: "They are all equal, but some are more equal."
panic mode
Joined Oct 10, 2011
5,469
so how close did you look what exactly did you see that makes any difference? did you decap the IC and measure lengths of interconnects? did you look at silicon? would it make difference for application in this topic (driving LEDs)?
ci139
Joined Jul 11, 2016
2,038
as i was browsing for some information - i also spotted an iC design that actually suggested that there might be a point to preffer certain order of signal routing . . . it was more obvious/true for that iC though
28,597
Consider the typical data sheets that provide timing information for the IC devices. There is a fair spread of delay times, which also are affected by temperature and supply voltage. Consider also that not all producers are even close to equal, or even similar.
panic mode
Joined Oct 10, 2011
5,469
all of that is true if one is interested in high speed and possibly exceeding rated values. on the other hand, none of that makes any difference for the application mentioned in this thread. even if the mentioned circuit had each of those ten inverters from a different IC made by different manufacturer, circuit as shown should still work exactly the same.
