Insights on Creating a microelectronic card for nanogrid
salhi
Joined Nov 29, 2023
86
I want to make a PCB (based on arduino NANO) for the management of a nanogrid consisting of a PV Solar and Wind Turbine and two storage batteries it has to contain current/voltage sensors along with ADC that send the data to arduino NANO for handling (decision making and Data storage in database) i want to know how to make this project with Proteus , i want to progress this project to make another nanogrid with the same components and make the same PCB to handle that new nanogrid properties (current/voltage/power consumptions/etc) so we can make the two nanogrids interconnected. Any help is very appreciated thanks!
WBahn
Joined Mar 31, 2012
33,348
As this is apparently some kind of assignment, you need to show your best efforts to work your assigned problem. We can help look over your work and help you identify where you might be going astray, but we aren't able to do your work for you.
salhi
Joined Nov 29, 2023
86
I dont want any work from the community just what should i do or where to start from?
WBahn
Joined Mar 31, 2012
33,348
Coming up with a where to start and figuring out what you should do is a big part of the assignment. YOU need to come up with your best attempt to get as far as you can, we can then help you past your current stumbling block to get just a bit further so that you can keep going.
salhi
Joined Nov 29, 2023
86
Have a look at what i did here using easyEDA
