Identifying a ECU component.
g60chubb
Joined Sep 13, 2014
18
So I'm having trouble with my Golf not starting and after much testing I've put down to a faulty ECU so opened it up and found what looks like a faulty resistor. 4 strip code indicates 21ohms and +_10% tolerance but i can't find a suitable replacement. Its from the early 90s but i'd like to think I could still get replacement bits.
Am I wrong?
Also I noticed its labelled as DR1 instead of just R does that mean it's not just a standard resistor?
g60chubb
Joined Sep 13, 2014
18
I think it's actually a solenoid. It's now just a case of finding a replacement... I think. I found this video and the guy says it.s a resistor and a guy in the comments seems to be sure its a solenoid.
g60chubb
Joined Sep 13, 2014
18
Found it. Inductor would probably be a better way of describing it. Ordered and en route. 22uh 10% tolerance.
ian field
Joined Oct 27, 2012
6,536
The resin coating looks like a chunk knocked off which suggests a drastic event, the P6K surge clamp diode nearby suggests it may be in a hazard prone part of the circuitry.
There's probably more damage than just the bit you can see.
g60chubb
Joined Sep 13, 2014
18
I'm suspecting that. I think the diodes might need changing. The caps are fine. I'll order up the diodes on the off chance. Hopefully I can sort it with that.
Cyraz1
Joined Sep 23, 2020
1
Hi, Did you manage to repair the ecu?
Hi Cyraz1,
Welcome to AAC.
The TS has not been on the site for about a year, so the chance of a reply is very low.
Please Create a new Thread, post as much detail as possible of your problem.
Moderation.
