Help in identifying component
Ya’akov
Joined Jan 27, 2019
10,322
Welome to AAC.
The grey cylinder in your photo is an axial ferrite bead. This is used for high frequency noise suppression and is just a wire with the ferrite surrounding it. It should measure as 0Ω (or the same as the shorted leads on the meter which may be higher than 0).
Pradeepb
Joined Sep 28, 2025
Welome to AAC.
Thank you @ Ya’akov. Yes it measures ~0ohms bidirectionally. I was suspecting a very small value resistor. I never would have guessed for ferrite bead. Thank you for prompt response.
