Identifying a ECU component.
Discussion in 'Automotive Electronics' started by g60chubb, Feb 19, 2017.
  1. g60chubb
    Sep 13, 2014
    12
    So I'm having trouble with my Golf not starting and after much testing I've put down to a faulty ECU so opened it up and found what looks like a faulty resistor. 4 strip code indicates 21ohms and +_10% tolerance but i can't find a suitable replacement. Its from the early 90s but i'd like to think I could still get replacement bits.
    Am I wrong?
    Also I noticed its labelled as DR1 instead of just R does that mean it's not just a standard resistor?
  2. R!f@@
    Apr 2, 2009
    9,647
    1,110
    Check with meter first.
  3. g60chubb
    Sep 13, 2014
    12
    I think it's actually a solenoid. It's now just a case of finding a replacement... I think. I found this video and the guy says it.s a resistor and a guy in the comments seems to be sure its a solenoid.
  4. g60chubb
    Sep 13, 2014
    12
    Found it. Inductor would probably be a better way of describing it. Ordered and en route. 22uh 10% tolerance.
  5. ian field
    Oct 27, 2012
    6,543
    1,195
    The resin coating looks like a chunk knocked off which suggests a drastic event, the P6K surge clamp diode nearby suggests it may be in a hazard prone part of the circuitry.
    There's probably more damage than just the bit you can see.
  6. g60chubb
    Sep 13, 2014
    12
    I'm suspecting that. I think the diodes might need changing. The caps are fine. I'll order up the diodes on the off chance. Hopefully I can sort it with that.
  7. g60chubb
    Sep 13, 2014
    12
    D8 is next in the chain. Apparently it's there to protect the rest of the board so fingers crossed.
  8. Kjeldgaard
    Member
    Apr 7, 2016
    332
    118
    The component number DR1 can also fit a Drossel in a German car.
  9. g60chubb
    Sep 13, 2014
    12
    Ah makes it clear now.
