Help identifying component
fallingcow
Joined Dec 4, 2018
7
I'm trying to repair some tool batteries. I think I identified the faulty part. It's the one with a hole burned through the middle. Can anyone help me identify what it is, and maybe point me to a supplier? If it's not clear in the pictures the numbers on it are 6358 and gv8619. I tried just googling the numbers but didn't find anything relevant. Thanks.
panic mode
Joined Oct 10, 2011
5,307
those are obviously power mosfets. the silkscreen also shows Qx label next to each of them. this looks like one of SO8 variants, (Power-SO8 or whatever) with pin4 being the mosfet gate. something like this:
https://www.mouser.ca/new/onsemi/onsemi-nvtfws002n04xm-mosfet/
or this
https://www.mouser.ca/datasheet/2/196/Infineon_ISC165N15NM6_DataSheet_v01_00_EN-3569911.pdf
those packages are commonly used on mosfets for high current and low to medium voltage.
logo on the transistors shows A inside a circle. that is Alpha and Omega. https://www.aosmd.com/
pretty sure "6358" is actually AON6358
