I need to condense my 2 3-8 decoders, but i cannot figure out why.
MARK.C
Joined May 16, 2018
6
I am also at the final part, i need to condense my 2 3-8 decoders but i cannot figure out why. My circuits look the same as Jessy1221
dl324
Joined Mar 30, 2015
18,321
Its in the marking criteria to use a 3 to 8 decoder
What school are you guys attending? Going from 3 inputs to 8 makes the problem more difficult (IMO).
Using the gear inputs more directly makes more sense. You can't use a standard logic block to do it, but it can be implemented with AND, OR, and NOT gates.
MARK.C
Joined May 16, 2018
6
Griffith Uni.
Unfortunately, this is what they want. So what would be the easiest way to go from the 2 3-8 decoders (16 outputs) and condense it into 1 led only using AND, OR and NOT gates?
dl324
Joined Mar 30, 2015
18,321
This is homework, so we can only give guidance.
How would you solve any other combinational logic problem that had 6 inputs and 1 output?
EDIT: And a belated Welcome to AAC!
dl324
Joined Mar 30, 2015
18,321
My difficulty is within this last section, I dont know how to connect the last part.
I don't think you're wiring the thing you're calling a selector correctly.
Can you post your lecture notes that covered doing something similar?
I can make the "selector thing" work, but it requires a brute force method for solving the problem.
