Need help for close-loop scalar control of induction motor
ingenieur_diao
Joined May 20, 2026
Hello everyone,
I am a final year electrical engineering student working on my graduation project (PFE), which involves the scalar V/f speed control of a 5.5 kW three-phase squirrel cage induction motor. This is urgent as my project deadline is approaching.
I have successfully implemented the open-loop V/f control in MATLAB/Simulink and obtained good results. However, I am struggling with the closed-loop implementation and would greatly appreciate any help or shared experience from someone who has worked on this topic.
Thank you in advance!
schmitt trigger
Joined Jul 12, 2010
2,291
Like Max mentioned, for closed loop control, an encoder or tachometer must provide the rotor velocity feedback.
Because induction motors MUST have slip to function, that rotor speed will always be less than the actual magnetic field rotation, and the amount of slip must be included in the algorithm.
However, the slip is not constant but varies with load, and thus a lookup table must be included to determine the actual slip value for precise speed control and, un extreme situations, prevent hunting.
For all those reasons, induction motors are not optimized for tight speed control.
MrAl
Joined Jun 17, 2014
13,893
Hello everyone,
A quick suggestion would be to first find a spice model of the motor you are dealing with, then go from there. You can work up equations from that too if you need that.
Of course a speed measuring device would be required, and possibly that could come as a shaft position sensor which provides more data as you can get velocity as well as acceleration from that which can help with better overall control.
