What does the voltage read when the 220 ohm resistor is connected?Hi there, I have made a flywheel with magnets attached and 4 power coils. the machine makes 55-60 volts when I put in a 220 ohm resistor the current only reaches 0.1amps, what could be going wrong? the current should be 0.25amps!
Also the magnets are as close as I can get them to the coil cores, any closer and then the magnets stick to the cores. I was thinking of dusting the magnets with iron filings so the cores make physical connection with the magnets.Bring the magnets as close as a paperthin to the coils and increase the speed.
Putting a 20 Ohm resistor across the output does nothing to prevent a short circuit. I cannot even imagine what you are thinking.I'm aware that you can't get more out than in. the 20 ohm resistor is to stop short circuit. The answer to the last question is there is 55 volts dc thats coming from the power coils ohms law states that V/R=I and so if it puts out 55v and the resistor of 220ohm the current should be 0.25amps not 0.1 I'm trying to figure out why I'm only getting 0.1amps!
