How to use MOSFETS and transistors
-live wire-
Joined Dec 22, 2017
959
I have found many YouTube videos explaining MOSFETS and transistors, but I still do not understand what exactly they do, and how to use them. Could someone please explain what you use them for and how to use them in a practical circuit?
#12
Transistors and mosfets allow you to use a small voltage or current to create or control (depending on how you look at it) a larger current flow which is very much proportional to the controlling voltage or current. This larger current can be seen as a lower impedance supply or a larger voltage depending on how you want to use it. This is how we get from tiny signals like a microphone, to a thousand watt speaker system. (But it takes more than one stage to do that job.)
BobTPH
Joined Jun 5, 2013
11,566
Perhaps that is your problem. Try reading a book written by someone with actual knowledge and teaching skills instead of relying on random people’s videos which may be entirely incorrect.
If you want help here, try to tell us what you think you understand, and what questions you still have.
Bob
spinnaker
Joined Oct 29, 2009
7,830
Good definition. I HATE the word amplifier. It is so misleading. The transistor or mosfet controls. Amplifies sounds like it is doing something magical (not that electronics isn't magical ;) ).
-live wire-
Joined Dec 22, 2017
959
Thanks. This has been helpful. I now have more of an idea of what they do. Just wondering, could you make a DC to (sinusoidal) AC inverter with just basic components like transistors, capacitors, resistors, that kind of stuff, or do you need complicated ICs? If you can, how would you go about doing it, and could you adjust the frequency by changing component values?
Audioguru
Joined Dec 20, 2007
11,248
You can make a very simple inverter that can power incandescent light bulbs and a heater. A more complicated inverter can be made to power electronic products.
Usually an inverter has its frequency fixed to the frequency of the electricity in its country, but a switch can change the frequency if you want.
Wendy
Joined Mar 24, 2008
23,797
I like helping people design things But I would be the first to say off the shelf device are more likely to cost less and have fewer unpleasant surprises.
