Compare MOSFETs specifications
andrew74
Joined Jul 25, 2022
273
Hello everyone, I’d like to compare the reverse recovery losses of two MOSFETs ( NVTFS010N10MCL and SiR510DP)
In the tables for the first MOSFET, the ‘*Body diode reverse recovery charge*’ is calculated under conditions IF = 20 A, di/dt = 100 A/μs, TJ = 25 °C … whereas in the tables for the second MOSFET, the conditions are IF = 8 A, di/dt = 300 A/s
But how can I make a comparison if the test used to determine Qrr is different?
This question also applies to parameters such as Trise and Tfall, where each MOSFET datasheet calculates them differently.
Moderators note : removed chrome extention from the links
