Need help
I have an old phone and I want to connect it with Relay 12v so that I can control a pump that is always working
When I call her, the pump turns off
I brought a Relay ,old phone, a transistor BC547 , a reset button, and a MOSFET IRF540N in order to maintain the state even after the excitement applied to it had stopped.
I designed the schema and tried the project on the Proteus software, it works normally, but when I delete the ground and rempalce it by connect it alone to the negative, the project does not work
