How to stop the car pump with a connection from the phone vibrator current
Delta Prime
Joined Nov 15, 2019
1,311
The video posted by the TS should help clarify. He is using the phone to disconnect the fuel pump in a car as an antitheft device.
To the thread starter I apologize.As stated I'm using a flip phone and cannot watch the video thank you for the clarification.
Edit :corrected typo
ericgibbs
Joined Jan 29, 2010
21,642
The thread starter is asking all the right questions the wrong way. In my humble opinion.
Hi Delta,
Please, less of the innuendo and paranoia, you are most likely offending a fellow member by suggesting he planning some sort of 'terrorist device'.
Moderation
ericgibbs
Joined Jan 29, 2010
21,642
hi z10,
Yes
You do not fit R1.
It looks OK and you have a normally open contact push button for the Reset.
Do you follow OK.?
E
Alec_t
Joined Sep 17, 2013
15,165
How is the phone to be connected in your circuit?
What is D2 for?
3V less the D2 drop is unlikely to turn on an IRF540N well, if at all.
zwawitotti10
Joined Aug 28, 2021
17
hi z10,
Yes
You do not fit R1.
Do you follow OK.?
E
I still haven't tried it yet because I'm traveling
But the problem is that when the call ends, the excites on the MOSFET gate will also end and it will be disconnected
ericgibbs
Joined Jan 29, 2010
21,642
Hi z,
Once excited the R3 voltage will hold ON the relay, until you short out the R2 resistor.
E
ericgibbs
Joined Jan 29, 2010
21,642
Hi alec.
The TS is using an ‘old mobile phone’ [in car] incoming call vibrate signal as an output voltage, states its about 9v.
This gates the MOS On and opens the electrical feed to the petrol pump, so shuts Off the engine.
When the relay contact changes over it puts +12V on the MOS gate as latch action, The diode is to prevent the 12V from feeding back into the vibrator.
The Reset push button shorts the MOS gate to 0v, releasing the relay.
It’s a car theft immobiliser.
If I follow the TS OK, it was working, but he wanted some way of Resetting the relay.
E
Alec_t
Joined Sep 17, 2013
15,165
Hi Eric. I get the principle, but I was concerned with the nitty-gritty of connections in the post #29 circuit (assuming that's what the TS is now working from.
ericgibbs
Joined Jan 29, 2010
21,642
hi alec,
Which parts of the circuit are you concerned about.?
I have never measured the actual vibrator voltage, but the TS says about 9Volts.??
If its lower then he will have to consider a Logic level MOSFET Gate.
E
Alec_t
Joined Sep 17, 2013
15,165
The vibrator motor might need spike suppression. Also, where does the '9V' come from? I was under the impression that phones ran on less than that, e.g. ~3.7V from a single lithium cell?
zwawitotti10
Joined Aug 28, 2021
17
hi z10,
Did you read my post #18, ref the relay contacts.?
E
Update:
Look at this option.
I applied it and it works fine but the restart button is not working
Please help me with the correct link of the reseat button because i think you should link between the Gate and Source to reseat as the datasheet
Look it to the video to see what happen
