How to stop the car pump with a connection from the phone vibrator current
zwawitotti10
Joined Aug 28, 2021
17
hi z10,
Look at this image, shows the Restart PB
E
yes i do like your schema, I know the picture is wrong and logically it won't work, but doesn't work
and I tried to turn the poles of the restart button, but there was a power back to the phone and then the phone was damaged
zwawitotti10
Joined Aug 28, 2021
17
i do like this schema it works normally, but it was a mechanical control , I took the vibrator off the phone connected by wire in Source, in front of a blade connected by wires to a Drain
and if the vibrator vibrates, it will touch the D with S this method operate normally until the restart works,
But I did not like the idea, as if the car moved violently, the vibrator would move and touch the razor and it will cut of the fuel pump
ericgibbs
Joined Jan 29, 2010
18,869
hi z10,
That latest circuit you posted is totally different from the version I posted.
The relay is latched by using the spare contact on the relay
I am not sure where you could add the reseat PB on your circuit.
E
