How to replace PIC16F676 with Arduino/ESP32?
MrNams
Joined May 20, 2023
24
Hello All,
I have auto switch for 3 Phase DOL starter with current sensor (using CT) and is working fine, i.e. is sense current and stop motor if it takes more current, it stops motor one phase failure, it working as expected, i just want to control it using ESP32 so that I read values and send it to cloud and based on that values give command to ESP32 to operate particular relay.
So, I want to remove PIC16F676 and use Arduino/ESP32. I know its hard to understand,what inputs given to PIC16F676, I want give a try.
Ya’akov
Joined Jan 27, 2019
10,368
The first step will be to reverse engineer the existing circuit. You’ll need to draw a schematic by following the traces on the PCB. Fortunately for you, it appears to be single sided which makes your work a lot easier.
schmitt trigger
Joined Jul 12, 2010
2,288
What is a DOL starter?
As Yaakov has mentioned, you will have to reverse engineer the board. Secondly, you will have to reverse engineer the software functionality. And layer your own functionality on top of it.
Also, since the pinouts are not compatible, instead of making a rat’s nest of wiring it would be far better to design your own PCB.
In other words, this is a full blown design project, in which you would be taking the existing product ONLY AS A BASELINE.
But hey! That is only my personal opinion.
MrNams
Joined May 20, 2023
24
I agree,i just want to reuse single phase preventer, dry run protection circuit on this board, and feed to Arduino than this pic.
