- Joined Jan 23, 2018
- 28,595
The HUGE benefit of a switching regulator is that it simply will block the excess voltage and not burn the unused power. A shunt regulator is what those folks in the 1960 era had available. The switching regulator will avoid all of that and avoid the whole problem of the higher voltage being able to cause problems.The whole point of the shunt regulator is to divert power from the load (the bulb) and into the MOSFETS so that bulbs don't keep blowing.
Why keep on insisting on using an incredibly obsolete inefficient system???
